HomePC DIYGuidesAir cooling vs. AIO liquid cooling: which CPU cooler is right for...
Air cooling vs. AIO liquid cooling: which CPU cooler is right for your build?
You picked the CPU. You selected the motherboard that your new CPU is going to call its home. Now you need to decide on a CPU cooler. Will you go the classic route with an air cooler, or will you install an all-in-one (AIO) CPU liquid cooler? One is a big block of metal with a fan, and the other involves a pump with a tube snaking to a radiator, but that’s just the beginning of the story. Both cool the chip, but they do it in different ways, and those factors can affect your build budget, full-PC cooling performance, and the aesthetics of your PC.
In this guide, we’ll walk through how each type works, how they fit into the airflow pathways of your PC, how that ripples out to the rest of the board, and which one fits your build.
The ROG Ryuo IV SLC 360 ARGB AIO CPU liquid cooler
Key takeaways:
  • Air cooling and AIO (all-in-one liquid) cooling are the two main ways to cool a CPU. For most builds either one works fine, but AIO coolers have an edge for cooling more quietly, cooling high-performance CPUs, or cooling in cases that don’t support tall air coolers.
  • The two cooling methods also differ when it comes to where the heat goes. An air cooler dumps heat straight into the case’s airflow, while an AIO moves heat to a radiator you can place wherever your case allows.
  • That heat placement matters more than ever. Modern cases, panoramic builds especially, often don’t follow the classic front-to-back airflow that air coolers were designed around, so an AIO’s control over where the heat goes and where it gets air is a real advantage.
  • Air coolers tend to be cheaper, but an AIO also comes with at least one fan. The price gap with air narrows once you factor in what upward of 3-4 quality case fans would cost separately.
  • For a build you want to show off, an AIO is the easy win. Pump displays, ARGB lighting, and a range of colorways mean there’s a liquid cooler for every aesthetic.
What’s the difference between air and liquid cooling?
PC builders have leaned on air cooling for quite some time. Newer models have refined the process, but the basics are still the same. A metal cold plate sits on top of the CPU, heat pipes transfer heat into a stack of fins that tower above the cold plate, and one or two fans push air straight through that fin stack. The heat travels from the chip, through the fins, and into the stream of air moving through the case.
An AIO liquid cooler has a similar starting point. There’s still a metal cold plate that moves heat away from your CPU’s heatspreader. But inside an AIO CPU liquid cooler’s pump housing, constantly moving coolant absorbs that heat and moves it to a radiator. Dedicated fans attached to that radiator move heat along, either straight out of your case or into its airflow pathway, depending on how you set things up.
Both approaches use fans to move air through a fin stack, but the “liquid” in a liquid cooler gives you more flexibility and control over where the heat from your CPU goes. An air cooler always has to do its work in the limited space right above the CPU socket, so its size is limited by things like the depth of your case. AIO CPU liquid coolers can get away with big, thick radiators since they have a mechanism for moving heat away from the region of your case right next to your CPU socket.
First and foremost, that’s often a big benefit for acoustic performance. Since the heat generated by your CPU gets spread out across a big, wide, radiator, the fans for that radiator don’t have to work quite as hard as they might otherwise, allowing for potentially quieter operation. Second, you get more choices for how your CPU cooling fits into your overall airflow plan. You can use the AIO CPU liquid cooler’s radiator as an intake, giving it access to absolutely fresh air, or you can use it as an exhaust to limit how much the heat from your CPU warms up your other components.
Where does the heat actually go?
With an air cooler, the heat from your CPU warms up a fin stack right in the middle of your chassis. The cooler’s job is to move that heat into the air, and then it’s up to the case’s airflow to carry that air out.
The ASUS Prime AP202 chassis as part of a completed gaming PC build
An AIO gives you a choice. The heat generated by your CPU still warms up some metal that dissipates heat as air is blown through it (the radiator), but now you get to choose where that warmed-up metal lives. Mount the radiator at the top of the case and the heat exits the top without substantially increasing the temps of any other component on its way out. Mount it at the front and the heat enters the case and gets carried wherever the case fans send it. This control over where the heat goes and where the radiator gets fresh air makes AIO CPU liquid coolers fit very well into the way modern cases are designed.
How does this affect the VRMs?
The VRMs, the voltage regulator modules around the CPU, are a crucial part of your PC’s operation. They convert the power rail into the low voltage your CPU runs on, and in the process they generate their own heat. On most motherboards they’re cooled by passive heatsinks that rely on case airflow to do the work. There’s no fan on them. They’re just metal, waiting for air to pass over them.
A closeup view of the AM5 socket on the ROG Strix X870E-E Gaming WiFi motherboard
That’s where your CPU cooler choice comes in. An air cooler’s fan (or fans) primarily move air through its own fin stack, but it also moves air across the top region of your motherboard. In conjunction with your case fans, an air cooler helps maintain a stream of air right over the VRM heatsinks.
When you’re using an AIO CPU liquid cooler, you might need to establish a plan for cooling your VRMs. Depending on where you install the radiator, you might not have enough air moving across the VRMs, leading to higher than expected VRM temperatures. Placing your radiator at the top of the case will generally position at least one of your AIO CPU liquid cooler’s fans where it can help exhaust the heat produced by your VRMs, but you might want to direct some cooling air at this region of your motherboard more specifically. Also, some AIO CPU liquid coolers include a fan embedded in the pump housing that keeps air moving around the CPU socket. That can help keep VRM temperatures low while retaining the convenience factor.
The big takeaway here: for long-term performance, VRM temperature is as important as CPU temperature, and the choices you make with your CPU cooling can make a big impact.
How do modern cases change the choice?
Air coolers were designed for the traditional PC case layout: one with a clear front-to-back airflow path. In this classic design, air enters the front, passes through the CPU cooler, and exits the back. Even today, that’s a very common layout, and air coolers shine in it. It means that your CPU cooling not only sits in the main airflow pathway of your case, but actively supports it.
An agentic AI PC build in the ASUS A31 chassis
That said, a lot of modern cases aren’t built that way anymore. Panoramic cases prioritize a wide-open view, turning the entire front of your chassis into an airflow-blocking window. Small-form-factor cases vary widely, but typically constrain your cooling options in a way that might tip the balance toward liquid cooling. Such a case might not offer sufficient depth for a big tower cooler, or it might not offer a simple front-to-back airflow pathway. In both chassis types, an air cooler might not be the best fit.
In such cases, an AIO CPU liquid cooler can be a real problem-solver. These coolers are a great choice for bottom-to-top airflow designs, as a 360mm radiator with three fans does incredible work exhausting heat while minimizing the possibility of dead zones in your case. They can help also ensure that you’re not limited by the airflow possibilities right around the CPU socket. For instance, that can allow you to take better advantage of a dual-chamber PC case.
Which one cools better?
For mainstream PC users with mainstream CPUs, both cooler types can offer more than enough performance. A modern mid-range chip tasked with spiky workloads like gaming rarely needs everything a cooler can give it, so a quality air cooler and a quality AIO will both keep it well within its limits. Note that not all coolers are made equal. A budget air cooler with a small fin stack and a puny fan isn’t going to keep up with a high-end AIO CPU liquid cooler.
Where the two cooler types start to separate is when you’re looking at high-end CPUs under a sustained, heavy workload. A gaming and streaming rig, a workstation doing long renders, or a build you’re overclocking pushes the cooler closer to its ceiling. That’s where liquid cooling tends to pull ahead: the larger radiator surface and the liquid loop can keep a high-end chip cooler over a long load than an air cooler of equivalent quality.
So the honest answer is that AIOs pull ahead on sustained cooling under hard load. For a build that mostly idles and games in bursts, the gap is small enough that you should let other considerations drive your decision-making process.
Which one is quieter?
Under light load, they’re close. Both run quietly when the chip is barely working. The pump in an AIO CPU liquid cooler is designed to run at a constant speed, which can lead to a certain amount of operational noise, but a well-designed model shouldn’t make noise that rises above the sound floor of your system.
A complete PC setup featuring ROG hardware
Under heavier loads, especially sustained ones, an AIO generally wins. Because the radiator spreads the heat over a larger area, the fans can spin slower to move the same heat, and the setup stays a notch quieter than the air cooler’s fan has to be to keep the chip in check. If you run long, loud loads in a room where you can hear your PC, the liquid setup tends to stay quieter.
One caveat: a small AIO with a compact radiator and fast-spinning fans probably win awards for quiet operation. The acoustic advantage comes from the bigger radiators, so a 360mm setup will out-quiet a 240mm one by a fair margin. AIO CPU liquid coolers with smaller radiators
Which one is easier to install?
Both are straightforward now, though air coolers have an edge when it comes to ease of installation. Modern air coolers clip on with a backplate and a couple of screws, with maybe a different mounting bracket depending on whether you’re installing an Intel or AMD CPU.
AIOs are a little more involved. There’s a pump to mount on the CPU, a radiator to screw onto the case, tubing to route, and getting the tubes to sit without kinks takes a bit of care. You might need to install fans to the radiator, and those fans will need to be hooked up to your motherboard. Any ARGB elements or fun things like a display on the pump housing will also need their own connections.
Generally speaking, modern AIO CPU liquid coolers have closed the gap when it comes to ease of installation. A model pre-installed, daisy-chain fans takes out a lot of the install work. But there are more steps involved.
If you want the cleanest possible AIO install, our ROG Strix LC IV series pairs with select new AM5 motherboards to use our AIO Q-Connector technology. That hooks the pump, radiator fans, ARGB lighting, and the pump housing’s display all in one go. You won’t have to plug in any cables, so you can put the zip ties back on the shelf and keep the build looking tidy.
Does the look matter?
If you’re building a case with a glass side and you want it to look good, an AIO is the easy win, and the options are genuinely fun. The pump housing itself is a feature now: the ROG Strix LC IV series carries a 5.08-inch IPS display on the pump, and the ROG Ryuo IV SLC 360 ARGB puts a 6.67-inch curved AMOLED screen there. Add ARGB lighting, colorways to match a black or white build, and the radiator and fans running in a clean line up top, and an AIO gives you far more to play with aesthetically than an air cooler does.
The ROG Ryuo IV 360 SLC ARGB AIO CPU liquid cooler in a completed build
An air cooler can look great too, and some are genuinely beautiful, but a big fin tower sits right over the middle of the board and can crowd your view. For a showpiece build, the AIO is where the fun is.
Is a liquid cooler more expensive?
Up front, a quality air cooler usually costs less than a comparable AIO. But the gap is smaller than it looks, because an AIO comes with three radiator fans included. If you’re going to need case fans for airflow, and most builds do, those three fans are a meaningful part of the bill, and an AIO hands you the fan kit along with the cooling. Once you factor in what three quality case fans would cost separately, the price difference between the two options isn’t quite as big as the sticker prices suggest.
Which one should you pick?
Your buildPickWhy
Classic front-to-back case
Mid-range CPU
Air coolerSufficient cooling
Low cost
Build that already needs case fansAir cooler + case fans
Either choice is reasonable
Panoramic or SFF caseAIO CPU liquid coolerMore control over airflow
High-end CPU
Sustained loads
Overclocking
AIO CPU liquid coolerCooler and quieter under long, heavy workloads
Showpiece buildAIO CPU liquid coolerOptional pump display
Cleaner layout
Better component visibility
A closeup view of the memory slots in a completed build featuring the ROG Crosshair X870E Glacial motherboard
Frequently asked questions
Is an AIO better than air cooling?
For a modern case and a build you want to look good, often yes. An AIO gives you control over where the CPU’s heat goes and where it gets air, which fits cases that don’t follow the classic front-to-back path, and it keeps a high-end chip cooler and quieter under sustained load. For a classic case with a clear airflow corridor, a good air cooler is still a solid, lower-cost choice. The right answer depends on your case, your chip, and what you want the build to look like.
Which is better for a small form factor build?
Usually an AIO. SFF cases are packed too tightly for a big air cooler tower to do its job, and they often don’t have the front-to-back airflow that air coolers rely on. An AIO with a radiator on the top or front panel gives the CPU heat a dedicated exit that doesn’t depend on the case’s airflow path.
Do AIOs help with VRM cooling?
They change the equation. In conjunction with the exhaust fans for your case, an air cooler keeps air moving over the VRM heatsinks and helps cool them. With an AIO CPU liquid cooler, it depends on how and where you place the radiator and its fan, and whether or not the pump housing has a dedicated fan for VRM cooling.
Do AIOs come with fans?
Yes. Almost all AIO CPU liquid coolers include sufficient fans for moving air through its radiator. An AIO CPU liquid cooler with a 360mm radiator includes three 120mm radiator fans, for instance. If you need case fans for airflow, which most builds do, that’s a meaningful part of the cost included, and it narrows the price gap with an air cooler.
Does the AIO size matter?
Yes. The radiator size (120mm, 240mm, or 360mm) sets how much surface area you have to dump heat. A 360mm radiator cools and stays quieter under load than a 120mm one, so if your case fits a larger radiator, that’s the cooler and quieter choice.
Whichever you pick, the goal is the same: a cooler that keeps the chip and the board around it in check under the loads you actually run, and fits the case you’ve chosen. For a classic case with a clear front-to-back path, a good air cooler is a budget-friendly choice. For a modern case, a high-end chip, or a build you want to show off, an AIO is the pick.
RELATED ARTICLES
Most Popular
