Not that long ago, a 240Hz display was a premium slab of pixels, offering refresh rates transcending the 120/144Hz monitors mained by mere mortals. These days, you don’t have to look far to find a 4K 240Hz display, and 1440p/1080p monitors can reach even higher speeds. All that means that if you bought a monitor in the last couple years, odds are pretty good that it’s a speed demon — or at least it could be, if your system could maintain FPS at a clip worthy of your refresh rate.
Unfortunately, too many gamers right now have a monitor that eclipses the capabilities of their PC. They have a competitive edge in their sights. But no matter how they fuss with the in-game graphics settings, they can’t quite get their FPS to break past a hidden ceiling. If this sounds familiar, you’ve likely encountered the silent performance killer for competitive gamers: a CPU bottleneck.
Oftentimes, the culprit for low FPS is your graphics card. But perhaps you’ve already upgraded that component and are still looking for answers. Achieving truly high FPS gaming PC performance requires a different approach. For esports titles where every frame counts, your CPU and motherboard serve a vital (and not always appreciated) role. This guide will show you how to perform a CPU bottleneck gaming fix and optimize your PC for high refresh rate monitors, creating the ultimate competitive gaming PC build.
The hidden bottleneck: why your CPU matters for high FPS
In gaming, your CPU and GPU work as a team. The CPU processes game logic, player inputs, and prepares “draw calls” — instructions for what the GPU needs to render. The GPU then takes those instructions and renders the frame. In visually stunning single-player games at 4K, the GPU is almost always the primary limiting factor or “bottleneck.” In other words, it’s the part of your PC that you should focus on upgrading if you’re looking for higher performance.
But in esports titles at 1080p or 1440p, the opposite is often true. Many gamers find that it’s the CPU holding back the show here, not the GPU. To hit 240 frames per second, your CPU must prepare 240 frames of data for the GPU every single second. If your CPU can only prepare 180 frames, your GPU will sit idle waiting, and some of the capabilities of your cutting-edge 240Hz monitor will be languishing unused.
Identifying a CPU bottleneck
Think you might have a CPU bottleneck? A simple test can help confirm it. While your game is running, open Windows Task Manager (Ctrl+Shift+Esc) and go to the Performance tab. In most gaming scenarios, your GPU utilization should be running close to 100%. If it’s not, then you’re likely hitting a CPU or RAM bottleneck.
A few caveats and exceptions to keep in mind here. First, don’t fret if you’re not seeing 100% CPU usage. Today’s CPUs often offer more cores and threads than games are optimized to take advantage of. Esports games in particular are often heavily dependent on single-core CPU performance, so you might be facing a CPU bottleneck even if your CPU utilization is less than 50%. Second, there might be other reasons why your GPU utilization is less than 90% while you’re gaming. An older game might not actually tax your graphics card that hard, or you might have a frame rate limiter running somewhere in the pipeline.
All that said, low GPU utilization is often a red flag that you have a mismatched GPU and CPU. To get the most out of your graphics card (and monitor!) a CPU upgrade could go a long way.
Choosing the best CPU for esports
When upgrading your CPU for competitive gaming, you’re looking for high clock speeds, excellent single-core performance, and sufficient cores for not just your game, but for keeping up with all the multitasking you typically have going on when using your PC. Broadly, that means that you’re best served with a current-gen CPU. You can squeak by with four cores for some games, but aiming for six is better, and eight cores is sufficient for most gamers most of the time. The PC users who seek out CPUs with more cores than that are generally building machines for tasks in addition to gaming.
Recent AMD processors have proven to be favorites among gamers thanks to their AMD 3D V-Cache technology. The AMD Ryzen 7 9800X3D is one of the best-selling CPUs on the planet. Need to pair that premier gaming performance with even more cores and threads? Snag an AMD Ryzen 9 9950X3D. For gamers on a tighter budget, the AMD Ryzen 5 7600X3D beckons.
Fans of Intel processors have rich options, too. Recent Intel chips have made noise in the midrange of the market, with the Intel Core Ultra 7 Processor 270K offering excellent value for around $300 (USD).
One final thought about picking a CPU for an esports rig. Given the memory shortage of 2026, some gamers are building machines with last-gen parts so that they can roll with less-expensive DDR4. If you’d like to learn more about the ins and outs of this approach, we’ve published some more information here.
The foundation of speed: your ASUS gaming motherboard
A high-performance CPU is only as good as the foundation it’s built on. An ASUS gaming motherboard provides the stable power, high-speed memory support, and low-latency connectivity needed to extract every ounce of performance from your new processor. As the central nervous system of your competitive rig, it’s the connective tissue that makes everything work together smoothly.
For a durable, no-nonsense build that delivers exceptional value, the TUF Gaming series is a perfect choice. A board like the TUF Gaming Z890-Plus WiFi is your ticket to overclocking-ready fun with an Intel Core Ultra Processor (Series 2). Built with military-grade components and an upgraded power solution, this motherboard ensures that your CPU receives clean, stable power to maintain high clock speeds during intense, prolonged gaming sessions.
If you’re seeking every possible competitive edge, the ROG motherboard family has the upgrade you need. But while it’s the no-holds-barred ROG Crosshair and ROG Maximus boards that steal most of the headlines, ROG Strix series boards are perennial favorites among gamers who want a balance of performance, value, and style. Offering premium features designed for enthusiasts in a more accessible package, the ROG Strix B850-A Gaming WiFi can kick your AMD processor into a higher gear through features like PBO Enhancement.
Key motherboard features to look for
When selecting your motherboard, prioritize these features to ensure you can max out your monitor’s potential:
- Start with compatibility. Make sure your new board has the socket that supports the CPU of your choice, and then check for the memory standard that it supports. Modern motherboards require DDR5.
- Secure robust power delivery. A higher VRM count distributes the work of providing stable, consistent power to the CPU. For long-term performance from a high-end CPU, a premium power solution is worth some investment.
- Get the storage options you need. Basically all motherboards these days offer at least a couple M.2 slots, but motherboards differ when it comes to how many M.2 drives they support, how many high-end PCIe 5.0 drives you can run, and the out-of-the-box cooling you get for these drives.
- Invest in connectivity. Higher-end motherboards tend to have more USB ports and higher-bandwidth networking options, but also pay attention to the speed and versatility of the port selection.
Unchain your frame rate
You invested in a high-refresh-rate monitor to gain a competitive advantage. Don’t let an underpowered CPU and motherboard hold you back. When you upgrade what matters most for high-FPS gaming, you can finally unlock the full potential of your display and your skills.
