HomeInside ASUSNewsThe TUF Gaming monitor lineup kicks into high gear with dual-mode tech,...
The TUF Gaming monitor lineup kicks into high gear with dual-mode tech, amped-up refresh rates, and a monitor arm
When gamers go shopping for a new monitor, they often have quite a checklist of specs and features that they require. But one element is always at the top of the list, and that’s speed. The latest TUF Gaming monitors take LCD technology to new heights in configurations that amp up the refresh rate for fast, ultra-fluid visuals.
The calling card of these new TUF Gaming monitors might be speed, but they’re also incredibly easy to integrate into your setup thanks to a refined stand design. Quick-release installation makes setup a breeze, and the new stand is significantly smaller than last-gen. Trading the outstretched supports for a compact base, the stand won’t demand much of your desktop space to provide sturdy support. It maintains a full range of ergonomic adjustments so that you can get the perfect viewing angle.
A TUF Gaming monitor
For gamers who prefer the tried-and-true combination of a 27-inch panel and a 1440p resolution (2560 x 1440), we’re launching the TUF Gaming VG27AQML5F. This monitor wields a Fast IPS panel with an incredibly fast 320Hz refresh rate. Paired with the low 0.3ms GTG response time (minimum), this speedy refresh rate ensures ultra-smooth, clear visuals for fast-paced gaming experiences. AMD FreeSync Premium and G-SYNC Compatible tech ensure low-latency, tear-free gaming. To boost motion clarity even further, activate ASUS Extreme Low Motion Blur Sync (ELMB SYNC), which reduces ghosting while maintaining support variable refresh rate tech.
In the past, too many gamers had to compromise on image quality to get a high refresh rate. Not anymore. The VG27AQML5F delivers vibrant, saturated colors, as attested by its 95% coverage of the cinema-grade DCI-P3 color gamut. Additionally, it’s designed with the contrast and brightness necessary to meet the requirements of a VESA DisplayHDR 400 certification.
An ultrawide TUF Gaming monitor
Here’s a first for ASUS gaming monitors: the combination of dual-mode monitor tech and an ultra-wide aspect ratio. The TUF Gaming VG34WQML5F is a 34-inch 3440×1440 gaming monitor with a 1500R curvature. In its standard mode, this display offers fast, clear visuals with its 240Hz refresh rate and 0.5ms GTG response time (minimum). That’s plenty fast for most scenarios, but this monitor has a higher gear ready and waiting to boost your competitive ambitions. Activate Frame Rate Boost, and the monitor kicks the refresh rate all the way up to 480Hz by dialing back the resolution to 1720×720.
The VG34WQML5F pairs its speedy visuals with all the other essentials you expect from an LCD gaming monitor. AMD FreeSync Premium ensures tear-free visuals, and this monitor also offers a VESA DisplayHDR 400 certification and 95% coverage of the DCI-P3 color gamut, ELMB tech for boosted motion clarity, and our new space-saving stand design.
A TUF Gaming monitor attached to the TUF Gaming AAS02 monitor arm
Even with the new stand design of these monitors, you might find yourself in a scenario where you need even more options for setting up your display. That’s why we’re also launching the TUF Gaming Monitor Arm AAS02. The monitor arm attaches to your desk via a sturdy c-clamp or a grommet mount, nearly eliminating the desktop space required by the display. The monitor supports monitors with a screen size up to 32 inches and up to 10kg in weight for flat displays, and up to 7kg for curved displays. Using the arm gives you wide-ranging options for raising and extending your monitor, while keeping everything tidy with cable management channels.
For more information on the pricing and availability of the TUF Gaming VG27AQML5F, TUF Gaming VG34WQML5F, and TUF Gaming Monitor Arm AAS02 in your region, please contact your local ASUS representative.
RELATED ARTICLES
Most Popular
