HomeInside ASUSNewsThe ZenScreen portable monitor family expands with an ePaper touch monitor and...
The ZenScreen portable monitor family expands with an ePaper touch monitor and an ultraportable stand
You might know ePaper display technology from the world of e-readers. Offering a paper-like reading experience with low power consumption, this display tech makes it easy and comfortable to travel with a large library of reading material. But the advantages of ePaper make it a compelling choice for use cases far beyond reading a novel by the pool. To bring this display tech to much wider audiences and use cases, we’re debuting the ASUS ZenScreen MP13UC. Equipped with a high-resolution color ePaper display, this portable touch monitor offers incredible versatility, and it’s bundled with our latest space-saving portable monitor stand, the ASUS ZenScreen Stand ATS01D. Let’s take a closer look.
Next-gen ePaper display experiences
Early variations of ePaper display panels were a bit limited in the experience that they could offer. If you haven’t checked in on the tech since the days of monochrome-only e-readers, you’re in for a treat.
The ZenScreen MP13UC is equipped with a 13.3-inch ePaper panel with a detailed 3200 x 2400 resolution. That works out to an ultra-sharp 300 PPI for crisp text and clear images, all in a versatile and roomy 4:3 aspect ratio.
Early ePaper displays earned their name by providing a paper-like reading experience, but within certain limitations. The ZenScreen MP13UC takes a bold step forward in reproducing the experience of reading text and signage in a digital format. First is breaking the monochrome barrier with support for up to 4,096 colors. ASUS ghosting-free technology enhances text clarity by automatically limiting the ghosting issues present with ordinary e-ink products. Finally, we’re able to offer an elevated refresh rate for smoother scrolling and clearer presentation of dynamic content.
Eye comfort is a major reason why people prefer ePaper displays in many contexts. The ZenScreen MP13UC is TÜV-certified to provide ultimate eye comfort with zero blue light and zero flicker. Additionally, we go above and beyond to give you comfortable viewing in any environment. Continuous color temperature tuning allows you to freely customize color temperature values to best fit ambient lighting conditions, rather than being limited to a small number of preset options.
Incredible versatility
As a portable monitor with standard USB Type-C input, the ZenScreen MP13UC is ready to go wherever you need it. It’ll connect easily to Windows 11 PCs. In such a setup, you can use ASUS DisplayWidget Center to refine the experience. This app enables intelligent power management for optimized charging and energy efficiency. Additionally, you can access auto-rotation support via DisplayWidget Center so that you can seamlessly switch between landscape and portrait modes.
The ePaper display tech has a trick up its sleeve that ordinary display technology can’t match. It doesn’t need power to display a static image. Even when the monitor is powered off, it can still show the image of your choice. This means that you can use it for digital signage or as a photo frame, even in scenarios where it’s impossible or inconvenient to keep it constantly supplied with power.
Given the ZenScreen MP13UC’s versatility, we suspect that you’ll end up using it in a wide variety of scenarios. To make this portable touch monitor easy to deploy anywhere, we’re bundling it with the ZenScreen Stand ATS01D. We’ll also be selling this stand individually, but it’s the perfect partner for the MP13UC. This portable stand can hold screens up to 16 inches and up to 1.2kg, and it offers wide-ranging ergonomic adjustments including height, tilt, and 90° pivot. A ¼-inch tripod socket and VESA wall mounting support (75 x 75mm) make it readily compatible with many devices, and it offers quick-release functionality for speedy setup and teardown.
The ZenScreen Stand ATS01D is incredibly easy to travel with, too. This lightweight stand folds up neatly to fit inside its included compact carrying pouch.
The ZenScreen MP13UC portable ePaper touch monitor and ZenScreen Stand ATS01D create incredible possibilities
For many contexts, the ePaper display technology provided by the ZenScreen MP13UC is transformative. This portable touch monitor provides comfortable viewing of a wide range of content in any scenario, whether that’s scanning through a stack of business documents or upgrading the checkout counter of your small business with high-quality digital signage. The ZenScreen Stand ATS01D elevates the versatility even further, giving you a space-saving and sturdy option for viewing content in a design that’s just as portable the display itself.
The rear panel of the ZenScreen MP13UC portable monitor on its stand
For more information on the pricing and availability of the ZenScreen MP13UC and ZenScreen Stand ATS01D in your region, please contact your local ASUS representative.
RELATED ARTICLES
Most Popular
