HomeInside ASUSNewsTUF Gaming TF120 ARGB fans let you upgrade your airflow for less
If your PC is starting to feel the heat during long gaming sessions, it might be time to give your cooling setup a boost. To make it easy, we’re currently offering a 14% discount on the TUF Gaming TF120 ARGB 3-pack in classic black. For a limited time, you can grab this triple-threat cooling kit for just $59.99, helping you maintain peak performance without breaking the bank.
High-performance cooling with a quiet touch
The TUF Gaming TF120 ARGB fans provide a perfect balance of power and stealth. They utilize an advanced fluid dynamic bearing rated for an incredible 250,000 hours, ensuring your system stays cool for years to come. For the user, the PWM control means the fans only spin as fast as they need to, while integrated anti-vibration pads keep things quiet even when your PC is working hard.
  • 76 CFM airflow: Moves a massive volume of air through your case to keep high-end components at stable temperatures. Balanced noise levels ensure that you get solid airflow without distractions.
  • Double-layer LED array: Delivers deeper color saturation and more vibrant lighting effects compared to standard RGB fans.
  • Bundled ARGB hub: Includes a dedicated controller that supports up to four fans, making it easy to sync your lighting with Aura Sync.
  • Versatile 120mm size: Designed to fit perfectly in almost any chassis position.
Lighting the way to a better build
Beyond just keeping things cool, these fans make your rig look its best. The double-layer LED structure ensures that light is emitted evenly through each fan blade, avoiding the “washed out” look of cheaper alternatives. Because this 3-pack includes its own multi-function controller, you can adjust brightness, speed, and color modes with ease, even if your motherboard doesn’t offer enough ARGB headers to support your desire for more fans.
At $59.99, the TUF Gaming TF120 ARGB chassis fan 3-pack is a fantastic opportunity to add some durable, high-luminance flair to your setup. You’ll also find great prices on similar TUF Gaming fans, including reverse airflow and white options.
RELATED ARTICLES
Most Popular
